[media]http://www.youtube.com/watch?v=H2kufs_87SA[/media]
Not ready to don a Google Glass headset? An alternative way to access smartphone content could hang around your neck.
A digital device disguised as a necklace or brooch could one day project email, tweets and text alerts onto nearby surfaces, allowing you to open them with hand gestures.
"The projector gives you a window into the virtual world that you carry around like a flashlight, as a way of serendipitously accessing information," says Christian Winkler at the University of Ulm in Germany. His team's Ambient Mobile Pervasive Display generates a green "SMS" graphic that is projected ahead of the user (see video above). To find out who the message is from, you hold your palm in front of you and the sender's name is projected onto it. To read the message, you make a gesture, such as a subtle swipe, and the text is displayed on your hand.
The idea is that most functions that normally require a screen can be performed in this way. So, to access your running distance from a fitness app, or a football score, you could customise gestures that will project the results on your hand. The team thinks the system will be especially useful in navigation, projecting arrows on the ground, and for location-aware adverts.
Getting focused
Switching from a projection on the ground to a hand image isn't easy because the projector has to alter its focal length instantaneously. But a Kinect-style 3D sensor solves the problem by calculating the distance to the ground and to the user's hand. The projector uses this information to refocus. The 3D sensor is also used to recognise gesture controls.
In a test system – which the team is confident can be scaled down – a laptop carried in a backpack controlled the projector and sent emails and Facebook updates to the device so that it could display them. A consumer version could be feasible in two years for indoor use and later for outdoor use, Winkler says, as LED-based projectors improve in brightness, use less power and shrink in size. New camera and smartphone models already come equipped with built-in projectors.
William Coggshall, an analyst based in Menlo Park, California, who has studied the future of projector technology, is cautious about how useful the proposed system will actually be. "The size and power of a device that could project onto a sidewalk in daylight may make it pretty clunky," he says. "And the hand is not a very flat or uniform screen so a message of any meaningful length might not be very legible."
The system will be presented at the annual computer-human interaction conference in Toronto, Canada, in April.
- It is currently Wed Nov 11, 2026 8:26 pm
Necklace projectors will throw emails onto the floor
