How to > DataGridView > Technical Logic >
.NET programming topics
Re: How to > DataGridView > Technical Logic >
Post by Neo » Mon Jan 04, 2010 1:28 am
Try this connection string.
"data source=sqlec; initial catalog=Northwind; integrated security=SSPI; persist security info=False; Trusted_Connection=Yes"
Neofriend
Post by Neofriend » Mon Jan 04, 2010 8:31 pm
Okay, I can load the data now and the grid view is showing up.
But there is no highlighting of rows. I changed the query as per my database namely "select * from transaction_tbl"
and I have a msg_status field having 0 or 1, I've tried using both the code people shared at csharpcorner for converting the rows to bold.
It isn't helping though.
Please let me know what can I do....
Post by Neo » Tue Jan 05, 2010 12:26 am
Post a screenshot of the grid with loaded data along with the code that you have under the "Go" button.
Neofriend
Post by Neofriend » Tue Jan 05, 2010 11:12 am
private void button1_Click(object sender, EventArgs e)
            for (int rowIndex = 0; rowIndex < dataGridView1.Rows.Count; rowIndex++)
                if (dataGridView1.Rows[rowIndex].Cells["msg_status"].Value != null)
                    if ((bool) dataGridView1.Rows[rowIndex].Cells["msg_status"].Value)
                        //read mail
                    else
                        //Unread Mail
                        dataGridView1.Rows[rowIndex].DefaultCellStyle.Font = new Font(Font.FontFamily, Font.Size,
        FontStyle.Bold);
            //foreach (DataGridViewRow r in dataGridView1.Rows)
            //    if ((Convert.ToInt32(r.Cells[6].Value) == 1))
            //        //Set Row Font to Bold
            //        r.DefaultCellStyle.Font = new Font("Arial", 12, FontStyle.Bold);
Post by Neo » Tue Jan 05, 2010 12:17 pm
It seems that you have changed the button code to something else. Can you use the one that I have tested with VS.2005 pls.
                if ((Convert.ToInt32(r.Cells[3].Value) == 1)) // change 3 to the index of the selection field
Basically you just have to change the column index (in red colour) of line if ((Convert.ToInt32(r.Cells[3].Value) == 1)) to the field index of the table in grid.
Note that if you do not need the particular field to appear on the grid, you can hide that column from code.
Neofriend
Post by Neofriend » Tue Jan 05, 2010 12:42 pm
Yes, I first tried doing that. Exactly the same way you mentioned. But it didn't work.
Working at your end?
Post by Neo » Tue Jan 05, 2010 12:53 pm
Note that the index is starting from 0. If the filed is appearing on the 5th column, the index is 4.
Neofriend
Post by Neofriend » Tue Jan 05, 2010 1:20 pm
Cool, its working now -
The mistake was... I was not pressing the button :) sorry...
Having some more questions regarding the same. But let's give this thread a bit of rest :)
Neofriend
Post by Neofriend » Tue Jan 05, 2010 1:21 pm
But yes one important thing, how can we hide that status column from design view and code?
Neofriend
Post by Neofriend » Tue Jan 05, 2010 1:36 pm
Alright, I've found out... its
dataGridView1.Columns[6].Visible = false;
Thank you :)
Doing more research and practice, you are of great help.
Return to “.NET Programming”
