Time Traveling
Time Traveling
Will Time Traveling Be Possible?
Re: Time Traveling
Warning: These things can confuse your mind. So better read after your A/Ls
However this is an interesting topic especially for physicists. I was also learning things based on this and according to my knowledge there are two possible ways.
We are stuck in this time-space frame with our limited senses. We can't see anything beyond relative to time with this physical body (it is called we are stuck in a box and we can't see beyond). If we break that (through meditation), we may see past-present-future are something that made us travel in this universe indefinitely from life to life. Once mind is developed, we might understand that there isn't anything called past-present and future. It is just our senses that made us think relative to time. When there is no past-present and future, you can exist anywhere you want at any time in any shape.
I think what we call "irdi prathiharya" is about time travelling. It may be a special sense which can override us from thinking relative to time.
Also when we break our limits of senses (and see out of the box), we would see something which can't be explained by an ordinary person. A person who has a sense to know past and future (Those are called "Pubbe Niwasanussathi" and "Chuthupa pada"). A person who can see and hear things anywhere in the universe (again not relative to time). I think the shortest and the easiest path to understand all these is about developing our own mind based on the "Arya Ashtangika Margaya" which was invented and explained precisely by Lord Buddha over 2500 years ago.
- Do more scientific experiments on Time-Space theory of Prof. Albert Einstein Most of these theories are postulated with infinite speeds. We didn't even achieve the speed of light yet so we can't predict anything at this moment. However Einstein has given a good example. Say there are twins who are born almost at the same time. One of them are kept in Earth and the other sent to Universe. Einstein states, on return, both twins are not in the same age.
- Theravada Buddhist Meditation (Found in countries like Sri Lanka, Thailand and Myanmar)
There were many occasions that Lord Buddha and Mugalan Thero had travelled to several worlds with different dimensions. You might have heard the example of Mugalan Thero who lost his routes while trying to find and end of the universe. According to the book, Lord Buddha had sent a light and then sound using that to get him back. He was advised not to do these type of dangerous travels. Note that if you do it today, there is no such powerful person to get you back, so be careful
"Irdi Prathiharya" is quite interesting. The moment you close your eyes, you can exist in another location (may be even in a different dimension like a heaven).
See what Prof. Einstein quoted about Buddhism. He quoted Buddhism as the only religion which can exist in future with the new inventions on science.
Buddhist meditation is a science that you need to do experiments on your own mind. You are free to go up to your limit and the path is well explained in Buddhism. I'm sure there will be a day where both science and Buddhism overlaps each other and go parallel to invent extra-ordinary things.
Re: Time Traveling
OK. I'll Read Those Web Sites After My A/L. But I Read your Post
Re: Time Traveling
ime travel is the concept of moving between different points in time in a manner analogous to moving between different points in space, either sending objects (or in some cases just information) backwards in time to some moment before the present, or sending objects forward from the present to the future without the need to experience the intervening period (at least not at the normal rate).
Although time travel has been a common plot device in fiction since the 19th century, and one-way travel into the future is arguably possible given the phenomenon of time dilation based on velocity in the theory of special relativity (exemplified by the twin paradox), as well as gravitational time dilation in the theory of general relativity, it is currently unknown whether the laws of physics would allow backwards time travel.
Any technological device, whether fictional or hypothetical, that is used to achieve time travel is commonly known as a time machine.
Some interpretations of time travel also suggest that an attempt to travel backwards in time might take one to a parallel universe whose history would begin to diverge from the traveler's original history after the moment the traveler arrived in the past.
Time travel in theory
Some theories, most notably special and general relativity, suggest that suitable geometries of spacetime, or specific types of motion in space, might allow time travel into the past and future if these geometries or motions are possible. In technical papers, physicists generally avoid the commonplace language of "moving" or "traveling" through time ('movement' normally refers only to a change in spatial position as the time coordinate is varied), and instead discuss the possibility of closed timelike curves, which are worldlines that form closed loops in spacetime, allowing objects to return to their own past. There are known to be solutions to the equations of general relativity that describe spacetimes which contain closed timelike curves (such as Gödel spacetime), but the physical plausibility of these solutions is uncertain.
Relativity states that if one were to move away from the Earth at relativistic velocities and return, more time would have passed on Earth than for the traveler, so in this sense it is accepted that relativity allows "travel into the future" (although according to relativity there is no single objective answer to how much time has 'really' passed between the departure and the return). On the other hand, many in the scientific community believe that backwards time travel is highly unlikely. Any theory which would allow time travel would require that problems of causality be resolved. The classic example of a problem involving causality is the "grandfather paradox": what if one were to go back in time and kill one's own grandfather before one's father was conceived? But some scientists believe that paradoxes can be avoided, either by appealing to the Novikov self-consistency principle or to the notion of branching parallel universes (see the possibility of paradoxes below).
Using wormholes
Wormholes are a hypothetical warped spacetime which are also permitted by the Einstein field equations of general relativity, although it would be impossible to travel through a wormhole unless it was what is known as a traversable wormhole.
A proposed time-travel machine using a traversable wormhole would (hypothetically) work in the following way: One end of the wormhole is accelerated to some significant fraction of the speed of light, perhaps with some advanced propulsion system, and then brought back to the point of origin. Alternatively, another way is to take one entrance of the wormhole and move it to within the gravitational field of an object that has higher gravity than the other entrance, and then return it to a position near the other entrance. For both of these methods, time dilation causes the end of the wormhole that has been moved to have aged less than the stationary end, as seen by an external observer; however, time connects differently through the wormhole than outside it, so that synchronized clocks at either end of the wormhole will always remain synchronized as seen by an observer passing through the wormhole, no matter how the two ends move around.[This means that an observer entering the accelerated end would exit the stationary end when the stationary end was the same age that the accelerated end had been at the moment before entry; for example, if prior to entering the wormhole the observer noted that a clock at the accelerated end read a date of 2007 while a clock at the stationary end read 2012, then the observer would exit the stationary end when its clock also read 2007, a trip backwards in time as seen by other observers outside. One significant limitation of such a time machine is that it is only possible to go as far back in time as the initial creation of the machine;in essence, it is more of a path through time than it is a device that itself moves through time, and it would not allow the technology itself to be moved backwards in time. This could provide an alternative explanation for Hawking's observation: a time machine will be built someday, but has not yet been built, so the tourists from the future cannot reach this far back in time.
According to current theories on the nature of wormholes, construction of a traversable wormhole would require the existence of a substance with negative energy (often referred to as "exotic matter") . More technically, the wormhole spacetime requires a distribution of energy that violates various energy conditions, such as the null energy condition along with the weak, strong, and dominant energy conditions.However, it is known that quantum effects can lead to small measurable violations of the null energy condition, and many physicists believe that the required negative energy may actually be possible due to the Casimir effect in quantum physics.Although early calculations suggested a very large amount of negative energy would be required, later calculations showed that the amount of negative energy can be made arbitrarily small.
In 1993, Matt Visser argued that the two mouths of a wormhole with such an induced clock difference could not be brought together without inducing quantum field and gravitational effects that would either make the wormhole collapse or the two mouths repel each other. Because of this, the two mouths could not be brought close enough for causality violation to take place. However, in a 1997 paper, Visser hypothesized that a complex "Roman ring" (named after Tom Roman) configuration of an N number of wormholes arranged in a symmetric polygon could still act as a time machine, although he concludes that this is more likely a flaw in classical quantum gravity theory rather than proof that causality violation is possible.
general relativity
Another approach involves a dense spinning cylinder usually referred to as a Tipler cylinder, a GR solution discovered by Willem Jacob van Stockum in 1936 and Kornel Lanczos in 1924, but not recognized as allowing closed timelike curvesuntil an analysis by Frank Tipler in 1974. If a cylinder is infinitely long and spins fast enough about its long axis, then a spaceship flying around the cylinder on a spiral path could travel back in time (or forward, depending on the direction of its spiral). However, the density and speed required is so great that ordinary matter is not strong enough to construct it. A similar device might be built from a cosmic string, but none are known to exist, and it does not seem to be possible to create a new cosmic string.
Physicist Robert Forward noted that a naïve application of general relativity to quantum mechanics suggests another way to build a time machine. A heavy atomic nucleus in a strong magnetic field would elongate into a cylinder, whose density and "spin" are enough to build a time machine. Gamma rays projected at it might allow information (not matter) to be sent back in time; however, he pointed out that until we have a single theory combining relativity and quantum mechanics, we will have no idea whether such speculations are nonsense.
A more fundamental objection to time travel schemes based on rotating cylinders or cosmic strings has been put forward by Stephen Hawking, who proved a theorem showing that according to general relativity it is impossible to build a time machine of a special type (a "time machine with the compactly generated Cauchy horizon") in a region where the weak energy condition is satisfied, meaning that the region contains no matter with negative energy density (exotic matter). Solutions such as Tipler's assume cylinders of infinite length, which are easier to analyze mathematically, and although Tipler suggested that a finite cylinder might produce closed timelike curves if the rotation rate were fast enough, he did not prove this. But Hawking points out that because of his theorem, "it can't be done with positive energy density everywhere! I can prove that to build a finite time machine, you need negative energy."This result comes from Hawking's 1992 paper on the chronology protection conjecture, where he examines "the case that the causality violations appear in a finite region of spacetime without curvature singularities" and proves that "here will be a Cauchy horizon that is compactly generated and that in general contains one or more closed null geodesics which will be incomplete. One can define geometrical quantities that measure the Lorentz boost and area increase on going round these closed null geodesics. If the causality violation developed from a noncompact initial surface, the averaged weak energy condition must be violated on the Cauchy horizon."However, this theorem does not rule out the possibility of time travel) by means of time machines with the non-compactly generated Cauchy horizons (such as the Deutsch-Politzer time machine) and in regions which contain exotic matter (which would be necessary for traversable wormholes or the Alcubierre drive). Because the theorem is based on general relativity, it is also conceivable a future theory of quantum gravity which replaced general relativity would allow time travel even without exotic matter (though it is also possible such a theory would place even more restrictions on time travel, or rule it out completely as postulated by Hawking's chronology protection conjecture).
Experiments
Certain experiments carried out give the impression of reversed causality but are interpreted in a different way by the scientific community. For example, in the delayed choice quantum eraser experiment performed by Marlan Scully, pairs of entangled photons are divided into "signal photons" and "idler photons", with the signal photons emerging from one of two locations and their position later measured as in the double slit experiment, and depending on how the idler photon is measured, the experimenter can either learn which of the two locations the signal photon emerged from or "erase" that information. Even though the signal photons can be measured before the choice has been made about the idler photons, the choice seems to retroactively determine whether or not an interference pattern is observed when one correlates measurements of idler photons to the corresponding signal photons. However, since interference can only be observed after the idler photons are measured and they are correlated with the signal photons, there is no way for experimenters to tell what choice will be made in advance just by looking at the signal photons, and under most interpretations of quantum mechanics the results can be explained in a way that does not violate causality.
The experiment of Lijun Wang might also give the appearance of causality violation since it made it possible to send packages of waves through a bulb of caesium gas in such a way that the package appeared to exit the bulb 62 nanoseconds before its entry. But a wave package is not a single well-defined object but rather a sum of multiple waves of different frequencies , and the package can appear to move faster than light or even backwards in time even if none of the pure waves in the sum do so. This effect cannot be used to send any matter, energy, or information faster than light,so this experiment is understood not to violate causality either.
The physicists Günter Nimtz and Alfons Stahlhofen, of the University of Koblenz, claim to have violated Einstein's theory of relativity by transmitting photons faster than the speed of light. They say they have conducted an experiment in which microwave photons - energetic packets of light - traveled "instantaneously" between a pair of prisms that had been moved up to 3 ft (0.91 m) apart, using a phenomenon known as quantum tunneling. Nimtz told New Scientist magazine: "For the time being, this is the only violation of special relativity that I know of." However, other physicists say that this phenomenon does not allow information to be transmitted faster than light. Aephraim Steinberg, a quantum optics expert at the University of Toronto, Canada, uses the analogy of a train traveling from Chicago to New York, but dropping off train cars at each station along the way, so that the center of the train moves forward at each stop; in this way, the center of the train exceeds the speed of any of the individual cars.
Some physicists have attempted to perform experiments which would show genuine causality violations, but so far without success. The Space-time Twisting by Light (STL) experiment run by physicist Ronald Mallett is attempting to observe a violation of causality when a neutron is passed through a circle made up of a laser whose path has been twisted by passing it through a photonic crystal. Mallett has some physical arguments which suggest that closed timelike curves would become possible through the center of a laser which has been twisted into a loop. However, other physicists dispute his arguments
Using wormholes
general relativity
Experiments
Re: Time Traveling
It is interesting to read...
thank you for starting that topic.
I also started reading about that topics because of you....
Re: Time Traveling
[media]http://www.youtube.com/watch?v=E2sp-clMk8s[/media]
[media]http://www.youtube.com/watch?v=SafwXdP7ylc[/media]
[media]http://www.youtube.com/watch?v=oRWwI61so5Q[/media]
[media]http://www.youtube.com/watch?v=X02WMNoHSm8[/media]
[media]http://www.youtube.com/watch?v=m5UcJt6RoIs[/media]
[media]http://www.youtube.com/watch?v=pH_p9HUAvik[/media]
Re: Time Traveling
Thanks for all
Re: Time Traveling
Welcome friend....
Re: Time Traveling
I found a Site with a Video and I saw this Video on TV too.
Here is the site
http://upodcasting.com/1163/proof-that- ... vel-exists
I made a Comment there. Here is the comment
Here is the site
What Do you think about my Idea?If this Is True, How Is she making Phone Calls without any Network Coverage? I think at that time people even didn't Use mobile Phones in their dreams.
Re: Time Traveling
No One ??
