<?php
class dbClass
var $dbHost;
var $dbName;
var $dbUser;
var $dbPass;
var $conn;
var $result = array();
var $output = array();
var $numrows;
var $current_query;
function dbClass($dbHost, $dbName, $dbUser, $dbPass)
$this->dbHost = $dbHost;
$this->dbName = $dbName;
$this->dbUser = $dbUser;
$this->dbPass = $dbPass;
// Open Database connection ---------
function openConnection()
$this->conn = mysql_connect($this->dbHost, $this->dbUser, $this->dbPass)or die ("Error Connecting to Database!");
mysql_select_db($this->dbName);
// Close Database Connection --------
function closeConnection()
mysql_close($this->conn);
// Return Single Row in Array -------
function queryRowArray($sql)
$result = @mysql_query($sql);
if (!$result)
echo "<br>Error: ".mysql_error();
return(false);
else
$output = @mysql_fetch_array($result);
$this->current_query = $sql;
return($output);
// Return result in 2D Array -------
function query2DArray($sql)
$datapool = array();
for($i=0;$i<$this->queryNumRows($sql);$i++)
$datapool[$i] = mysql_fetch_array($result);
return $datapool;
// Return Row Count -------
function queryNumRows($sql = "")
if ($sql == "")
$sql = $this->current_query;
if (!$result)
return(false);
else
$numrows = @mysql_num_rows($result);
return($numrows);
// Return Column Count --------
function queryNumCols($sql = "")
if ($sql == "")
if (!$result)
return(false);
else
$numcols = @mysql_num_fields($result);
return($numcols);
// Insert Or Update -------
function execCommand($sql)
$result = mysql_query($sql)or die("<br><br>Error:".mysql_error()."<br><br>");
return $result;
// Show list of tables in database ----------------
function showTables()
$result = @mysql_query("SHOW TABLES;");
for($i=0;$i<mysql_num_rows($result);$i++)
$datapool[$i] = mysql_fetch_row($result);
return $datapool;
// Show list of databases -------------------------
function showDatabases()
$result = @mysql_query("SHOW DATABASES;");
return $datapool;
// Get Latst Insert ID ---------------------------
function getLastInsertID()
$result = @mysql_query("SELECT LAST_INSERT_ID();");
if (!$result)
return(false);
else
return($output[0]);
// Return Column Information ----------------------
function getColumnInformation($sql)
$result = @mysql_query("SHOW COLUMNS FROM ".$sql.";");
$this->current_query = "SHOW COLUMNS FROM ".$sql.";";
return $datapool;
// End Of Database Class -------------------------------
include('phpdb.php');
$a = new dbClass($dbserver,$dbname,$dbuser,$dbpass);
$a->openConnection();
$result = $a->query2DArray("SELECT * from table");
$a->closeConnection();
