A trouble with JDM programmer
Re: A trouble with JDM programmer
Post by Rksk » Thu Apr 29, 2010 5:16 pm
It is too not working
Magneto
Post by Magneto » Thu Apr 29, 2010 5:22 pm
Now you have three more things to do.
1. remove the cable from the PC and directly short the Pin 2 and Pin 3 of your computer serial port. And as you did ,
write someting on the hyperterminal and see , wheter you can see what you are typing. This test has no effect of the
cable and if this fail , we can definetly say your computer COM port has some problem and then you have to go for another computer.
2. If above test is successful , check continuity of your serial cable in femal and male sides.
That mean check the continuity of femal pin 2 and male pin 2. and check the continuity of femal pin 3 and male pin 3.
if this is ok , we can think that your cable is ok.
3. Or else you can ask serial cable from your friend and try or you can buy a new one and try. They are not expensive.
Post by Rksk » Thu Apr 29, 2010 5:30 pm
dear friend,
please tell me any other way to do these on same computer :( :idea:
I can't try on another computer, Because finding a computer is very hard in my village>>>>>
ThankZZZZZZZZ. :arrow:
Magneto
Post by Magneto » Thu Apr 29, 2010 5:35 pm
Can you did the number one step of my above post and tell us the results
Post by Rksk » Thu Apr 29, 2010 5:53 pm
Dear Magneto,
It only shows that,
I think it says an error of my serial port (COM1).
COM2 has an error in settings.
COM2 settings.JPG (40.41 KiB) Viewed 21530 times
Can I resolve this problem and use COM2 with JDM ?
Thanks...
Post by Rksk » Thu Apr 29, 2010 11:19 pm
Friends,
Neo helped me to solve COM2's problem.
I had connected i internel modem to PC therefore COM2 have used by it and
COM2 had disabled in BIOS.
He helped me to find them and resolve by spending his worth time. :)
Thanks...
Post by Neo » Thu Apr 29, 2010 11:30 pm
You are welcome! :)
I'll sort out the IC problem as discussed with you.
Post by Rksk » Sun May 02, 2010 4:23 pm
Friends,
now the led on jdm programme is blinking when i try to erase all, read all, ...
but i can't write the hex file to the pic. it gots the error massage wich i have post at the start of this topic.
neo told me, the pic can be dammaged and he will help me...
dear neo,
i'm waiting for a PM from you.
thankz.
Post by Neo » Sun May 02, 2010 5:35 pm
I know how interested you are to make your first PIC project :)
One of our members hopefully will post you another 877 tomorrow. Lets hope that he will have some free time.
BR
Post by Rksk » Sun May 02, 2010 6:07 pm
Great... :)
i'm waiting for it. :(
Thanks.
