Does anyone know why this could be or has anyone had this problem before?
<?xml version="1.0" encoding="utf-8"?>
<settings>
<appearance>
<object param="useRandomOrdering" value="0" /> <!-- 0 or 1. if "1", the image order will be randomized -->
<object param="centerIfPossible" value="1" /> <!-- 0 or 1. if "1", the menu will check to see if it can center itself. only works if all the images fit inside the visible surface -->
<item spacing="3" align="center">
<!-- spacing - the distance, in pixels, between two images.
align - controls the position of the menu and the direction of the zooming effect.
values are: "center","top","bottom","left","right". top/left and bottom/right are interchangeable
<mainTween duration="0.7" delay="0" type="expo" method="easeOut" /><!-- the main tween effect that applies to the rolled over image (or to all rolled out). is secondary tween is missing, it's replaced by main -->
<secondaryTween duration="0.7" delay="0" type="expo" method="easeOut" /> <!-- the tween that is applied to items around the rolled over image. properties that are missing will default to the main tween ones. -->
type values: back, bounce, circ, cubic, elastic, expo, linear, quad, quart, quint, sine
for a more detailed view of these types of transitions you can visit http://hosted.zeh.com.br/tweener/docs/en-us/
method values: easeIn, easeOut, easeInOut, easeOutIn
for the linear type no ease function is available
SOME transitions WILL create bugs or break the menu (the transition function may spiral the image sizes to 0) ! test carefully! -->
</item>
<rollOverEffect type="none" min="0" max="3" />
<!-- image effects:
type values are: "none" and "blur". min is the default value, max is the value of the rolled over image. -->
</appearance>
<content>
<menuItem delay="1">
<!-- delay - the amount of time the autoplay will pause on this image. overrides globalAutoDelay. ONLY works when autoPlayType is "2" -->
<media type="image" src="images/tp1.png" minWidth="70" maxWidth="120" minHeight="60" maxHeight="100" link="index.html" target="_blank"/>
type values: "image"
src - path to image. all types supported (png preffered).
minWidth/maxWidth/minHeight/maxHeight - image dimensions. override the properties defined in the settings xml.
link - the address of the clickable link
target - the link display window. for javascript/asfunction target should be "_self".
"_blank" opens the link in a new window,
"_self" opens the link in the same window,
"_parent" opens the link inside the parent window/frame when using frames
"_top" opens the link in the top window
<text bkgndAlpha="70" bkgndColor="0x000000">
<!-- text that will be show in the tooltip.
bkgndAlpha:0..100 - tooltip background alpha. overrides the property defined in the settings xml.
bkgndColor:0x000000..0xFFFFFF - tooltip background color. overrides the property defined in the settings xml.
use these properties when the text isn't visible on the default ones.
<![CDATA[<p><b><font color="#E4522C" size="10" face="verdana" ><font size="13">H</font>ELLO, <font size="13">W</font>ORLD.. <br/><font size="13">A</font>GAIN!</font></b></p>]]>
</text>
<description>
<!-- text that will be shown in the description box -->
<![CDATA[<p><font color="#003355" size="10" face="verdana">Description goes <b>here</b>!</font></p>]]>
</description>
</menuItem>
<menuItem>
<media type="image" src="images/tp2.png" link="About.html" target="_self"/>
<text bkgndAlpha="90" bkgndColor="0x333333">
<![CDATA[<p><font color="#FFFFFF" size="11" face="verdana">This is the all-new <br/><b>X-treme DockMenu</b> <br/>from <font color="#FF6600"><b>FlashTuning</b></font>!</font></p>]]>
</text>
<description>
<![CDATA[<p><font color="#000000" size="10" face="verdana">No Flash editing needed!</font></p>]]>
</description>
</menuItem>
<menuItem>
<media type="image" src="images/tp3.png" link="Portfolio.html" target="_self"/>
<text>
<![CDATA[<p><font color="#EEF9FE" size="11" face="verdana">Fully customizable from <b>XML</b>!</font></p>]]>
</text>
<description>
<![CDATA[<p><font color="#000000" size="10" face="verdana">Listen to the wise tooltip</font></p>]]>
</description>
</menuItem>
<menuItem>
<media type="image" src="images/tp4.png" link="Employment.html" target="_self"/>
<text>
<![CDATA[<p><font color="#EEF9FE" size="10" face="verdana">Among the features:<ul><li class="liStyle">autoplay</li><li class="liStyle">blurring</li><li class="liStyle">description textboxes</li><li class="liStyle">FlashVars</li><li class="liStyle">highlighting</li><li class="liStyle">overshadows</li><li class="liStyle">randomizing</li><li class="liStyle">reflections</li><li class="liStyle">resizing</li><li class="liStyle">tooltips</li></ul></font></p>]]>
</text>
<description>
<![CDATA[<p><font color="#000000" size="9" face="verdana"> The position of the tooltip and the description box can be set from inside the xml.</font></p>]]>
</description>
</menuItem>
<menuItem>
<media type="image" src="images/tp5.png" link="Education.html" target="_self"/>
<text>
<![CDATA[<p><font color="#EEF9FE" size="9" face="verdana">We highly appreciate any feedback!<br/>Thank you to all the people that<br/> take the time to comment or email!</font></p>]]>
</text>
<description>
<![CDATA[<p align="right"><font color="#000000" size="10" face="verdana">All the text can be formatted using html/<font color="#884444"><b>css</b></font>.</font></p>]]>
</description>
</menuItem>
<menuItem>
<media type="image" src="images/tp6.png" link="C.V.html" target="_self" />
<text>
<![CDATA[<p align="center"><font color="#EEF9FE" size="11" face="verdana">Any questions?<br/>See the documentation or<br/> click to open the <br/><font size="12" color="#FFCC77"><b>FlashTuning</b></font> FAQ page.</font></p>]]>
</text>
<description>
<![CDATA[<p align="left"><font color="#000000" size="10" face="verdana">If neither help, please email/contact us.</font></p>]]>
</description>
</menuItem>
<menuItem>
<media type="image" src="images/tp7.png" link="Contact.html" target="_self" />
<text bkgndAlpha="90" bkgndColor="0xDEF3FE">
<![CDATA[<p align="left"><font color="#5F7480" size="11" face="verdana">Not convinced?<br/>Download the free version <br/>and test it yourself!</font></p>]]>
</text>
<description>
<![CDATA[<p align="left"><font color="#000000" size="10" face="verdana">Support us by spreading the word!</font></p>]]>
</description>
</menuItem>
<menuItem>
<media type="image" src="images/tp8.png" link="Photographs.html" target="_self"/>
<text>
<![CDATA[<p align="center"><font color="#EEF9FE" size="11" face="verdana">Special characters support:<br/>© !@#$%^ " &* ' < { ><br/>// \() ? ? Œ ‰ | ~ Æ »<br/> § € âæèêíó!</font></p>]]>
</text>
</menuItem>
</content>
</settings>
