Zen Cart Problem
Re: Zen Cart Problem
Great. So you are very close on the requirement now.
First investigate how to pass new products with it. When that is working, we can come to the last part "product image upload". If this is not already available, we will have to edit the submit page to get an input (link to the image as she has those already on her server?) and upload to exact field in the mysql database.
But Neo She Said That She have several thousand of Images. And he want to add images automatically too.
Okay... I assume, you were given a tab separated or comma separated file as below.
If this is the case, you import this to the database (may be you can specify the fields). In most of the systems I know, you can either provide the image as a URL or upload the image as raw data. If the system supports importing the image as URL, there is almost nothing you need to do. Just set the image to URL.
If the system doesn't support getting images through url, then you will have to modify the script to read the image in URL and then upload raw data to database.
ID NAME PRICE IMAGE_LINK
1 ITEM1 10.00 http://mysite.com/item1.jpg
2 ITEM2 12.00 http://mysite.com/item2.jpg
3 ITEM3 15.00 http://mysite.com/item3.jpg
4 ITEM4 16.00 http://mysite.com/item4.jpgIf the system doesn't support getting images through url, then you will have to modify the script to read the image in URL and then upload raw data to database.
She Needs to Upload those by a CVS file or any other file type. I think She has a List of Products. But I don't know about the images.
Ask her to provide you a sample CVS file. If it is image urls then the solution would be much much easier.
OK. I'll ask when she come tomorrow
Since this is project specific help, it should go under "Project Assistance". So I move it here.
It's OK
Hey Friends I've Got a Good News
This module can Insert images but they have to upload to zencat's image folder first.
I will ask if i need more helps
Big Help Wanted Neo.
I used the module well with my PC's Zen Cart but it isn't working well on Buyers Server
Here Zen Cart Version is Zen Cart v1.3.8a/v1.3.8
My one is
v1.3.9h
So I tried to try an older version but there are so many files to upload so it's hard
I think this will work if i update zen cart. but I'm afraid to it if i do so if it destroyed. I think it won't happen if i back up the data base but I'm afraid to that too.
Can you tell me a Way?
My one is
v1.3.9h
