PHP ?????????
PHP ?????????
?? ?? topic ?? ????? ?????? PHP ???? ???? ?? ????????? ?????.
NEO,NIPUNA ?????? ?? ??? ??????.
?? PHP ????? ????? ???.
?????????? start ???? ????.(?? ????? ?? forum ??? ????? ? ??????? ????? ????? ???? ??? ???? ???? ??????)
Re: PHP ?????????
Here I'm giving you 3 tutorials. Remember to follow only one at a time. So when are done with one, give a quick look to the other to see whether you miss any point. Always remember to try out all examples. Since you have already installed WAMP successfully we can simply move on to real work.
Good luck and hope to see a professional php developer !
- http://www.w3schools.com/php/php_syntax.asp
- http://www.tizag.com/phpT/index.php
- http://www.maconstateit.net/tutorials/PHP/default.htm
Re: PHP ?????????
????? ?????? ?? ?? USE ???.
http://www.w3schools.com/php/default.asp
?? Tutorial ?? ?????? Follow ?????
Re: PHP ?????????
??? ???? NIPUNA,
???? ???????.?? ??? ???? ???? ???? ???.?? ?? links ????? try ???? ???????.
???? ?? ?? ??? questions ???????.
Re: PHP ?????????
????? ?? ??? ?????? code ?? ????.
????? ????? my.php ???? save ???.
?? ????? ? file ?? wamp>www folder ??? copy ???.???? firefox adressbar ??? http://localhost/my.php ????? ?????.
<html>
<body>
<?php
echo "i learn pHp";
</body>
</html>?? ????? ? file ?? wamp>www folder ??? copy ???.???? firefox adressbar ??? http://localhost/my.php ????? ?????.
Re: PHP ?????????
Ela Ela. Kolla Wede allagena Wage
Re: PHP ?????????
????? ???? ??? ?????.?? ??? ?????? code ?? ??.???????? ?????? ????????.?????? code ???? ?????? ?? ?? try.
Re: PHP ?????????
Ela Ela Keep It Up
Re: PHP ?????????
?? ??????? ?? code 2
???? ?? print ???? ???? ???????? ???.
??????? ??? output ????? ??????.
?? code 2 ? ????????? ??????? ????? ??
<html>
<body>
<?php
echo "i learn PHP";
</body>
</html>Code: Select all
<html>
<body>
<?php
print "i learn PHP";
</body>
</html>?? code 2 ? ????????? ??????? ????? ??
Re: PHP ?????????
Mama Dunna Link eke tiyana widiyatanam Oya Dekenma Kerenne ekama de kiyala yama tibune
