Discrete Cosine Transformation (DCT)
Computer Graphics & Vision Topics
Max
Sergeant
Sergeant
Post by Max » Wed Sep 30, 2009 2:35 am
The discrete cosine transformation (DCT) helps separate the image into parts (or spectral sub-bands) of differing importance (with respect to the image's visual quality). The DCT is similar to the discrete Fourier transform: it transforms a signal or image from the spatial domain to the frequency domain.
DCT Encoding
The general equation for a 1D (N data items) DCT is defined by the following equation:
and the corresponding inverse 1D DCT transform is simple F^(-1)(u), i.e.:
where
The general equation for a 2D (N by M image) DCT is defined by the following equation:
and the corresponding inverse 2D DCT transform is simple F^(-1)(u,v), i.e.:
where
The basic operation of the DCT is as follows:
  • The input image is N by M;
  • f(i,j) is the intensity of the pixel in row i and column j;
  • F(u,v) is the DCT coefficient in row k1 and column k2 of the DCT matrix.
  • For most images, much of the signal energy lies at low frequencies; these appear in the upper left corner of the DCT.
  • Compression is achieved since the lower right values represent higher frequencies, and are often small - small enough to be neglected with little visible distortion.
  • The DCT input is an 8 by 8 array of integers. This array contains each pixel's gray scale level;
  • 8 bit pixels have levels from 0 to 255.
  • Therefore an 8 point DCT would be:
    where
    Question: What is F[0,0]?
    answer: They define DC and AC components.
  • The output array of DCT coefficients contains integers; these can range from -1024 to 1023.
  • It is computationally easier to implement and more efficient to regard the DCT as a set of basis functions which given a known input array size (8 x 8) can be precomputed and stored. This involves simply computing values for a convolution mask (8 x8 window) that get applied (summ values x pixelthe window overlap with image apply window accros all rows/columns of image). The values as simply calculated from the DCT formula. The 64 (8 x 8) DCT basis functions are illustrated below.
    DCT basis functions
  • Why DCT not FFT?
    DCT is similar to the Fast Fourier Transform (FFT), but can approximate lines well with fewer coefficients.
    DCT/FFT Comparison
  • Computing the 2D DCT
    • Factoring reduces problem to a series of 1D DCTs:
      • apply 1D DCT (Vertically) to Columns
      • apply 1D DCT (Horizontally) to resultant Vertical DCT above.
      • or alternatively Horizontal to Vertical.
      The equations are given by:
    • Most software implementations use fixed point arithmetic. Some fast implementations approximate coefficients so all multiplies are shifts and adds.
    • World record is 11 multiplies and 29 adds.
Downrange
Re: Discrete Cosine Transformation (DCT)
Post by Downrange » Thu Oct 15, 2009 5:29 pm
I believe the above representation of the DCT is incorrect. At a minimum, it does not produce the values given in the example under 'DCT basis functions'.
Lambda(i) should be Lambda(u) in the 1-D form.
The 2-D form is also affected.
(Link Removed)
Max
Sergeant
Sergeant
Post by Max » Thu Oct 15, 2009 6:18 pm
Downrange wrote: Lambda(i) should be Lambda(u) in the 1-D form.
I think it is right as Sigma i is used and refer to Image
Or else I do not understand your point. I'm open to discuss :)
Also, I have copied this article from a site as per request from a user. If you can explain DCT in a better way, you are welcome to add an article here.
Return to “Graphics & Vision”
