Java adding program
Java programming topics
Java adding program
Post by Face » Fri Apr 29, 2011 9:58 pm
Java adding program
I am using NetBeans & tring to make some codes Java.I used NetBeans tutorials & made a little code to make adding software(I dont know is it correct to use the word software :P )
GUI
GUI
AddNumbers.rar
(20.8 KiB) Downloaded 662 times
This is the project file I made in NEtBeans.Can you tell me is it good or any comments ??
Other question is I can run the project with NetBeans.But When I try to run the .jar file My PC open Nokia OVI suit :( can you help me on this?
Re: Java adding program
Post by Neo » Fri Apr 29, 2011 10:05 pm
Very good to see that you have shared your knowledge. This is the way to learn.
Try to install JRE (Java Runtime Environment) again. If it is already there, then try to change file association for .jar extension to open with JRE.
Post by Face » Fri Apr 29, 2011 10:30 pm
Ahh thanks NEO
I can run the project with NETBeANS.I think I have JRE in my PC.Netbeans ask to install JRE when I am going to install it.
I think Nokia OVI suit is the problem.Because It always ty to get that .jar file as an application to the mobile. :(
Do I have to delete it or any other option..??
other thing is I wanna make this simple thing as .exe program.How can I make it?Any software to do that?
(NEO what you say about that program I made?I am asking your Ideas.Did you run it? I wanna know that is my project file work well with others?)
Post by Neo » Sat Apr 30, 2011 12:30 am
No. I don't think so. Just change the file association for .JAR files to run with JRE instead of Ovi app.
Free products:
http://jsmooth.sourceforge.net/
Commercial products:
http://www.regexlab.com/en/jar2exe/
http://www.ucware.com/jexec/index.htm
No. I didn't. But I appreciate your passion on sharing what you did with others. I'm sorry I have no free time at all to run programs where I need to get some serious measures to pass through virus scanners, etc... But I would probably have a look on source code issues since it mostly takes no time at all for me.
Post by Nipuna » Sat Apr 30, 2011 8:57 am
Cool Man :)
Great to see you are Getting Good. :)
But Try to finish the Tutorials first then get full knowledge, Then you would be making More valuable Programs :)
Post by Face » Sat Apr 30, 2011 2:58 pm
Thanks machan NIPUNA!
Did you test the programm?How was it?Working fine or any error?I wanna test it.
And the other problem is I can run that .jar file still :( :( :(
NeO I could not understand this.Still I have the same problem!When I try to run the programm.Start Nokia OVi suit.
Post by Nipuna » Sat Apr 30, 2011 6:04 pm
Yes. I tested it's Running Well.
To change file association Do this.
Right Click on the Jar file and then Select Properties then at the General tab Click the Change Button then Select Java(TM) Platform SE
Then you are Ready to Go ;)
Post by Face » Sat Apr 30, 2011 7:40 pm
NIPUNA bro I don't have Java(TM)Platform SE in my dialog box :(
Do I have to Browse it ? I tried to browse it.But could not find it.
Post by Nipuna » Sat Apr 30, 2011 8:50 pm
You Must have it without that How you Code and Run them :)
Try Google a Bit to Find out about this because my default one is that so i didn't need to browse
Post by Saman » Sat Apr 30, 2011 11:46 pm
Nipuna is correct. You should get something like below. If not, browse for the JRE which might be already installed with NetBeans I guess. If you can't find it, you could install JRE separately.
Return to “Java Programming”
