I need some help to start application programming. Also would like to know how to select a programming language for a beginner.
Thanks in Advance,
John
How to start programming?
- LittleJohn
Re: How to start programming?
I have experience in programming for about 19 years now and I started computing when I was 11 with a Sinclair Spectrum like most of the guys in the good old era. So I thought I better give some help to get you started.
Also, when you learn the concepts right with C language, you can switch to C#, VB.Net, C++.Net, Java, Delphi, Ada or any other programming language quite easily.
I must tell you that I personally don't like Java for Applications. It is extremely slow as it has to pass through another layer called Java Virtual Machine which makes Java platform independent. I don't believe in Java platform independence as C/C++ performs a far more better role with cross compilers for almost all platforms in the world. In simple terms your C code will run under all common operating systems with simple porting.
However Java is essential for Web Programming. Javascript, JSP, AJAX all based on the principles of Java.
I think I have written a complete article which will give your a perfect start. (This is the way I have started and end up as a professional programmer, Tech lead and a CEO)
Good luck!
- RULE 1: Programming is a passion. You must love to sit in front of a computer long hours ( sometimes I did 20 hours a day
). When you love your computer, it will let you learn how to code it
- RULE 2: You must learn programming concepts first. "Concepts of Programming Languages - Sebesta" is a good book. It explains you the structures used in coding, so you can use any language you want as appropriate for different applications without fear. Learn some object oriented coding concepts.
- RULE 3: Learn Data Structures & Algorithms
These are the building blocks of programming. Stacks, Queus, Trees, Link lists, etc... Choose a book with reference to C/C++.
- RULE 4: Learn C/C++. Both are almost same (Don't worry about the differences for now. Just learn C).
Start with the following code.
#include <stdio.h>
void main(){
printf ("Hello World!\n");
return;
Don't get this small code simple. All genius coders started with this including Bill Gates.
- RULE 5: Learn Assembly Programming at least to some extent
Without knowledge in assembly, I don't employ any programmer in my organization. The reason is simple. People with a knowledge in ASM coding knows how computers are working. Others are just writing high level codes without knowing how they are converted to ASM at the end to make the electronic components of the computer to understand.
Good luck!
Nice post NEO.
I read It all.NIPUNA gave me the link to this.
I will start my career from 0--->infinity.(May be I fail,anyway I will try)
- miteshaegis
Very nice post, i also would like to programming. I am programmer. I was start to learn with c language, its basic language.
Yeah, very nice post. Learned a lot.
evangilbort
- Sergeant
If you want to learn a programming you can use any language tutorial available on the internet and also we watch the video tutorial. This is the best idea to learn programming and we can practices different languages.
It's all about one unexpected thing. I learned it early on in my programming career when I was interning at Microsoft.
