Combined Cycle Power Plants
Thermodynamics Topics
Magneto
Post by Magneto » Thu Oct 29, 2009 10:18 pm
Applications
Large scale power production
Overview
The Combined Cycle power plant is a combination of a fuel-fired turbine with a Heat Recovery Steam Generator (HRSG) and a steam powered turbine. These plants are very large, typically rated in the hundreds of mega-watts.
Depending on the power requirements at the time, the combined cycle plant may operate only the fired turbine and divert the exhaust. However, this is a substantial loss of efficiency. Large fired turbines are in the low 30% eff. range, while combined cycle plants can exceed 60% efficiency.
In a thermal power station water is the working medium. High pressure steam requires strong, bulky components. High temperatures require expensive alloys made from nickel or cobalt, rather than inexpensive steel. These alloys limit practical steam temperatures to 655 °C while the lower temperature of a steam plant is fixed by the boiling point of water. With these limits, a steam plant has a fixed upper efficiency of 35 to 42%.
An open circuit gas turbine cycle has a compressor, a combustor and a turbine. For gas turbines the amount of metal that must withstand the high temperatures and pressures is small, and lower quantities of expensive materials can be used. In this type of cycle, the input temperature to the turbine (the firing temperature), is relatively high (900 to 1,400 °C). The output temperature of the flue gas is also high (450 to 650 °C). This is therefore high enough to provide heat for a second cycle which uses steam as the working fluid; (a Rankine cycle).
In a combined cycle power plant, the heat of the gas turbine's exhaust is used to generate steam by passing it through a heat recovery steam generator (HRSG) with a live steam temperature between 420 and 580 °C. The condenser of the Rankine cycle is usually cooled by water from a lake, river, sea or cooling towers. This temperature can be as low as 15 °C
In an automotive powerplant, an Otto, Diesel, Atkinson or similar engine would provide one part of the cycle and the waste heat would power a Rankine cycle steam or Stirling engine, which could either power ancillaries (such as the alternator) or be connected to the crankshaft by a turbo compounding system.
Fuel for combined cycle power plants
Combined cycle plants are usually powered by natural gas, although fuel oil, synthesis gas or other fuels can be used. The supplementary fuel may be natural gas, fuel oil, or coal. Biofuels can also be used. Integrated solar combined cycle power stations are currently under construction at Hassi R'mel, Algeria and Ain Beni Mathar, Morocco [4]. Next generation nuclear power plants are also on the drawing board which will take advantage of the higher temperature range made available by the Brayton top cycle, as well as the increase in thermal efficiency offered by a Rankine bottoming cycle.
Configuration of combined cycle systems
The combined-cycle system includes single-shaft and multi-shaft configurations. The single-shaft system consists of one gas turbine, one steam turbine, one generator and one Heat Recovery Steam Generator (HRSG), with the gas turbine and steam turbine coupled to the single generator in a tandem arrangement on a single shaft. The key advantage of this single-shaft arrangement is its operating simplicity with higher reliability than multi-shaft blocks. Further operational flexibility is provided with a steam turbine which can be disconnected, using an SSS Clutch, for start up or for simple cycle operation of the gas turbine.
Multi-shaft systems have one or more gas turbine-generators and HRSGs that supply steam through a common header to a separate single steam turbine-generator. In terms of overall investment a multi-shaft system is about 5% higher in costs.
Single- and multiple-pressure non-reheat steam cycles are applied to combined-cycle systems equipped with gas turbines having rating point exhaust gas temperatures of approximately 540 °C or less. Selection of a single- or multiple-pressure steam cycle for a specific application is determined by economic evaluation which considers plant installed cost, fuel cost and quality, plant duty cycle, and operating and maintenance cost.
Multiple-pressure reheat steam cycles are applied to combined-cycle systems with gas turbines having rating point exhaust gas temperatures of approximately 600 °C.
The most efficient power generation cycles are those with unfired HRSGs with modular pre-engineered components. These unfired steam cycles are also the lowest in cost. Supplementary-fired combined-cycle systems are provided for specific application.
The primary regions of interest for cogeneration combined-cycle systems are those with unfired and supplementary fired steam cycles. Theses systems provide a wide range of thermal energy to electric power ratio and represent the range of thermal energy capability and power generation covered by the product line for thermal energy and power systems.
Return to “Thermodynamics”
