Introduction to FPGAs
Max
Sergeant
Sergeant
Post by Max » Tue Aug 18, 2009 9:21 pm
A field-programmable gate array (FPGA) is a semiconductor device that can be configured by the customer or designer after manufacturing—hence the name "field-programmable". FPGAs are programmed using a logic circuit diagram or a source code in a hardware description language (HDL) to specify how the chip will work. They can be used to implement any logical function that an application-specific integrated circuit (ASIC) could perform, but the ability to update the functionality after shipping offers advantages for many applications.
FPGAs contain programmable logic components called "logic blocks", and a hierarchy of reconfigurable interconnects that allow the blocks to be "wired together"—somewhat like a one-chip programmable breadboard. Logic blocks can be configured to perform complex combinational functions, or merely simple logic gates like AND and XOR. In most FPGAs, the logic blocks also include memory elements, which may be simple flip-flops or more complete blocks of memory.
Altera Cyclone.jpg (14.63 KiB) Viewed 4637 times
Xilinx SPARTAN.jpg (19.6 KiB) Viewed 4637 times
Architecture
The most common FPGA architecture consists of an array of configurable logic blocks (CLBs), I/O pads, and routing channels. Generally, all the routing channels have the same width (number of wires). Multiple I/O pads may fit into the height of one row or the width of one column in the array.
An application circuit must be mapped into an FPGA with adequate resources. While the number of CLBs and I/Os required is easily determined from the design, the number of routing tracks needed may vary considerably even among designs with the same amount of logic. (For example, a crossbar switch requires much more routing than a systolic array with the same gate count.) Since unused routing tracks increase the cost (and decrease the performance) of the part without providing any benefit, FPGA manufacturers try to provide just enough tracks so that most designs that will fit in terms of LUTs and IOs can be routed. This is determined by estimates such as those derived from Rent's rule or by experiments with existing designs.
A classic FPGA logic block consists of a 4-input lookup table (LUT), and a flip-flop, as shown below. In recent years, manufacturers have started moving to 6-input LUTs in their high performance parts, claiming increased performance.
Typical logic block.png (7.26 KiB) Viewed 4637 times
There is only one output, which can be either the registered or the unregistered LUT output. The logic block has four inputs for the LUT and a clock input. Since clock signals (and often other high-fanout signals) are normally routed via special-purpose dedicated routing networks in commercial FPGAs, they and other signals are separately managed.
For this example architecture, the locations of the FPGA logic block pins are shown below.
Logic Block Pin Locations.png (1.98 KiB) Viewed 4637 times
Each input is accessible from one side of the logic block, while the output pin can connect to routing wires in both the channel to the right and the channel below the logic block.
Each logic block output pin can connect to any of the wiring segments in the channels adjacent to it.
Similarly, an I/O pad can connect to any one of the wiring segments in the channel adjacent to it. For example, an I/O pad at the top of the chip can connect to any of the W wires (where W is the channel width) in the horizontal channel immediately below it.
Generally, the FPGA routing is unsegmented. That is, each wiring segment spans only one logic block before it terminates in a switch box. By turning on some of the programmable switches within a switch box, longer paths can be constructed. For higher speed interconnect, some FPGA architectures use longer routing lines that span multiple logic blocks.
Whenever a vertical and a horizontal channel intersect, there is a switch box. In this architecture, when a wire enters a switch box, there are three programmable switches that allow it to connect to three other wires in adjacent channel segments. The pattern, or topology, of switches used in this architecture is the planar or domain-based switch box topology. In this switch box topology, a wire in track number one connects only to wires in track number one in adjacent channel segments, wires in track number 2 connect only to other wires in track number 2 and so on. The figure below illustrates the connections in a switch box.
Switch box topology.png (20.4 KiB) Viewed 4637 times
Modern FPGA families expand upon the above capabilities to include higher level functionality fixed into the silicon. Having these common functions embedded into the silicon reduces the area required and gives those functions increased speed compared to building them from primitives. Examples of these include multipliers, generic DSP blocks, embedded processors, high speed IO logic and embedded memories.
FPGAs are also widely used for systems validation including pre-silicon validation, post-silicon validation, and firmware development. This allows chip companies to validate their design before the chip is produced in the factory, reducing the time to market.
FPGA Design and Programming
To define the behavior of the FPGA, the user provides a hardware description language (HDL) or a schematic design. The HDL form might be easier to work with when handling large structures because it's possible to just specify them numerically rather than having to draw every piece by hand. On the other hand, schematic entry can allow for easier visualisation of a design.
Then, using an electronic design automation tool, a technology-mapped netlist is generated. The netlist can then be fitted to the actual FPGA architecture using a process called place-and-route, usually performed by the FPGA company's proprietary place-and-route software. The user will validate the map, place and route results via timing analysis, simulation, and other verification methodologies. Once the design and validation process is complete, the binary file generated (also using the FPGA company's proprietary software) is used to (re)configure the FPGA.
Going from schematic/HDL source files to actual configuration: The source files are fed to a software suite from the FPGA/CPLD vendor that through different steps will produce a file. This file is then transferred to the FPGA/CPLD via a serial interface (JTAG) or to an external memory device like an EEPROM.
The most common HDLs are VHDL and Verilog, although in an attempt to reduce the complexity of designing in HDLs, which have been compared to the equivalent of assembly languages, there are moves to raise the abstraction level through the introduction of alternative languages.
To simplify the design of complex systems in FPGAs, there exist libraries of predefined complex functions and circuits that have been tested and optimized to speed up the design process. These predefined circuits are commonly called IP cores, and are available from FPGA vendors and third-party IP suppliers (rarely free, and typically released under proprietary licenses). Other predefined circuits are available from developer communities such as OpenCores (typically free, and released under the GPL, BSD or similar license), and other sources.
In a typical design flow, an FPGA application developer will simulate the design at multiple stages throughout the design process. Initially the RTL description in VHDL or Verilog is simulated by creating test benches to simulate the system and observe results. Then, after the synthesis engine has mapped the design to a netlist, the netlist is translated to a gate level description where simulation is repeated to confirm the synthesis proceeded without errors. Finally the design is laid out in the FPGA at which point propagation delays can be added and the simulation run again with these values back-annotated onto the netlist.
VHDL Code Sample (Simple AND Gate)
-- (this is a VHDL comment)
-- import std_logic from the IEEE library
library IEEE;
use IEEE.std_logic_1164.all;
-- this is the entity
entity ANDGATE is
   port (
         IN1 : in std_logic;
         IN2 : in std_logic;
         OUT1: out std_logic);
end ANDGATE;
architecture RTL of ANDGATE is
begin
  OUT1 <= IN1 and IN2;
end RTL;
Verilog Code Sample (Two simple flip-flops)
module toplevel(clock,reset);
 input clock;
 input reset;
 reg flop1;
 reg flop2;
 always @ (posedge reset or posedge clock)
 if (reset)
   begin
     flop1 <= 0;
     flop2 <= 1;
   end
 else
   begin
     flop1 <= flop2;
     flop2 <= flop1;
   end
endmodule
Return to “FPGA”
