How to scrap text from internet in VB
Visual Basic Topics
Re: How to scrap text from internet in VB
Post by Neo » Wed Sep 28, 2011 11:53 pm
:?: How use POST method?
	Dim req As XMLHTTP
	Set req = New XMLHTTP
	req.open "POST", "https://robot.lk/viewtopic.php", False
	req.setRequestHeader "Content-Type", "application/x-www-form-urlencoded"
	req.send "f=9&p=8633"
	Text1.Text = req.responseText
Post by Rksk » Thu Sep 29, 2011 12:42 am
Thank you. :)
Re: How to scrap text from internet in VB6
Post by Rksk » Sat Oct 08, 2011 12:01 pm
Neo wrote:
	Dim req As XMLHTTP
	req.open "GET", "https://robot.lk/index.php", False
	req.send ""
This works fine with remote hosts. But doesn't work with localHost. how do I resolve?
Thankz.
Post by Neo » Sun Oct 09, 2011 5:36 pm
Should work. Can you provide more details on the command line you use and the web server you are running.
If you are running WAMP, http://localhost/myfile.php should work. Be sure to use http:// prefix.
Post by Rksk » Mon Oct 10, 2011 8:34 am
vb errror2.jpg (94.97 KiB) Viewed 28468 times
Post by Neo » Mon Oct 10, 2011 3:11 pm
Worked on the first run!
I can't guess anything without seeing your code.
Post by Rksk » Wed Oct 12, 2011 12:26 pm
Yes, I found the error.
The computer must be connected to the internet to call localhost too.
It doesn't work, Without an internet connection.
I tried with Xampp. I don't know where is the problem.
Post by Neo » Wed Oct 12, 2011 12:45 pm
Try WAMP. It might work without an internet connection.
